I have a dana 30 4.88 gear set with probably 200 miles on them and the same for the truetrac. I'm building my waggy 44 now. $475 for both
Pm if you want em. I'll pull them Sunday.
Rusty's over the knuckle set up $375 Used Two wheeling trips
Comes with new weld on brackets for relocated sway bar links...the trac bar relocator is welded on as I had to install it and you'll need to buy that from Rusty's or simply use some plate as it's very simple.
