big cherokee
- portland oregon
im runnin a dana 30 hp with 37 and a lockright and yes you brake shafts not a ball joint yet but i just carry extra shafts and take it easy on the shinny pedal.
toyworx said:Super30 will put up with 35's no problem.
I run Q78's which are a little over 35" with a Locker, 27spline Superior Alloy's and CTM's and I bash that thing like a rental and haven't broken anything yet. Then again i'm $1200.00 just into the shafts and CTM's. If i didn't already have the 27 spline locker i would have gone with the 30spline super kit.
Big Red said:I'm so confused!!! I have a rev 30 with 4.56 gears and a arb and a rear xj dana 44 with 4.56 gears and a detroit and it has held up very good with no breakage on the rubicon and fordyce. I do watch it though and only use the arb when I need it, otherwise I keep the front end open.
I just got a hp44/9" for a pretty low price, the 44 has a lock rite and 3.50 gears, the 9"has a full detroit and 3.50 gears. I'm debating as to whether I should put these new axles under my jeep or just simply get alloy shafts with good u-joints for the 30? I run 35" pro comp xts and it has held up well to that and the hp 44 doesn't give you anymore u-joint strength that a 30 does and that is what breaks most of the time anyways.
Do you guys think I should spend the $ to get these axles geared to 5.38/5.43 and run them or sell them? The hp 44 has the rare leaf springs so I don't need to do the ford radius arms, I was thinking front leafs, but the guy that is might be setting up my gears told me to stay with the stock 4 link due to the unibody. I know I want to, but I'm on a tight budget right now. The 30 isn't that bad. I just use my xj to wheel, so it doesn't see lots of street miles.
Troy
hjeepxj said:D30's cant go past 4.88 gearing.
I guess you just answered your own question.
Big Red said:I knew that, I meant the hp44/9" gearing. With 35" tires, 4.88 are more ideal, but my 4.56 gears work too. Just getting to the trail and up the mountain passes takes a little more gas.![]()
hjeepxj said:Touche.
