I was wondering if anyone knew if the steering knuckles from an 87 XJ HP D30 and the sterring knuckles from a 97 TJ LP will interchange. I recently swapped out my LPD30 for an 87 HPD30 with factory 4.56 gears and the brakes now suck. Brakes were great with the 97 tj axle under the front, but have absolutely dissappeared with this 87 d30. The caliper mounts on each axle are just different enough to not interchange, so the only thing i can think of is swapping the entire knuckle and maybe replacing ball joints while im at it. Lemmie know if the dimensions are the same and if ya know itll work. Id search but im too lazy at this point.
Mike
Mike
