- Southern Maryland
I installed a HP30 a couple of years ago that has a whine in 4WD under load, shuts up immediately in 2WD coast. From what I've read this is the outer pinion bearing. I also have a leak on the pinion seal. I cleaned the whole thing and replaced the axle seals before installing it but did not know about the pinion problems at that time. The axle operates fine, no grinding or anything, just a little trouble with the pinion bearing and seal AFAICT. My basic plan is/was to get the pinion bearing and seal replaced at a driveline shop, and save a full rebuild for later if/when I regear and locker. I don't have a press or some of the other tools.
Come to find out the shop I use for engine work just bought a bunch of new toys for setting up gears and I may be able to get them to replace both bearings and redo the whole setup if I supply the parts.
The problem is I don't know what parts I should get. I know the part numbers for the outer and inner bearings and races and the pinion seal, but thinking I should get an overhaul kit of some kind with extra shims and crush and whatever. Yukon has a bunch of kits with different parts, FIIK what the difference between them
What do I need?
What do I need?
