D30 & 8.25 (27 spline)
Tenny
Houston, TX
Dana 30 (High Pinion, Reverse Cut, 27-spline axleshafts) from a '94 Jeep XJ. Has Axle shafts, but the hub is broken at the u-joints, no caliper included but discs are. Gears and everything else are in good condition.
Chrysler 8.25" (c-clip, non-ABS, 27-spline axleshafts) also from a '94 Jeep XJ (Cherokee). Good condition, brake pads are cracked though. Replaced because I swapped axles.
They are in the back of the jeep right now, and can deleiver if you are close for a small fee, or I can bring them to the Bay Area Meet & Greet if you want them then.
$50 if red. 60 if not.
(also posted on craigslist..)
what ratio?
if they fall through then i am interested in the 8.25
