I installed RC's drop brackets this week and added an inch to the 4 1/2" or so to my lift. Problem is to keep the pinion angle good I had to increase the length of my lower arms, uppers are in as far as they'll go. So now the axle's moved forward some and the sway bar's going to hit the springs. I know there are relocation mounts but that would mean I have to remove the front shield that came with the Upcountry. I like that sheild, it keeps some of the bigger crap from the front of the engine. I have JKS's discos and even extending them as far as I dare (gotta keep at least a few threads for strength), the sway bar still hits.
So, has anyone cut and drilled into the swaybar to relocate the mounting holes for discos? In the pics below the blue is where I want to cut to and the red's where I want to re-drill. Any thoughts would be helpful. Thanks
