southernrebel20
- Georgia
Nicely built bumper man. How was welding those .75" D-Ring mounts? Did you have to pre-heat, or do you have a serious mig machine?
Do you think you could tell me how much material and what type that you used just to make the bumper to this point. how much and what type of plate, how much and what type of rectangular tubing.
oh and one other thing, would you have took some large angle iron and reinforced the unitbody while you had it all cut apart that way it wouldnt get bent up? Seems like it would be a good idea if I have it all off to go ahead and do this, what do you think?
anybody feeling me on this?
I still don't understand, you never want to attach something stronger to something weaker if the something weaker you dont want broke. You can destroy your entire jeep but once the unitbody is done your done. So attaching super strong tubing to a weaker frame rail still doesnt make any sense to me. Now if you ran the super strong tube all the way down the inner of the unitbody I think that makes sense or if you have your entire unitbody sleeved with 0.25 plate then I can see your argument for the 0.25 tube there but I dont understand using it with the stock unitbody. Thats why they build all the crumple auto body panels today... they want the body to crumple and absorb the impact before the frame and your head does.
He said he was plating the frame for a full ton axle swap, yeah?
So the entire unibody is going to get something from 10 GA to 3/16" plate thrown on it.
Also, take into consideration that he isn't bolting this (massive, sexy) bumper into sheet metal. Well, he is, but the sheet metal is forming a well boxed structure - the uni body. If the rig gets plated, those bumper mounts should spread the load well enough to avoid any breakage -- bumper, bolts or body.
Unless the legends of his breaking abilities are true, that is...
What do you think about tapping the 2x4 itself, rather than messing with nutplates?
X2, and it's easy to tack a couple nuts down, so why not?Thats a good idea too, I just didnt feel like messing around with taps at the time. the only issue i can think of would be only having a 1/4" thickness for threads. ideally with a 1/2" bolt, youd want at least 3/8-1/2" thickness of threads to take full advantage of the fasteners strength.
How long were the 2x4 peices that went into the framerail? Im going to be ordering metal, and was wondering how much to get just to do those mounts?
