blistovmhz
- Vancouver, BC
98 XJ, WJ kuckles, 1 tonne crossover, 35x12.5, etc.
I've definitely got some rear steer going on due to bad leaf angle, but I'll be addressing that next week (was going to throw some 63" chevy leafs in today, but everything's closed for the long weekend
The rear steer however, is NOT the cause of my wandering steering and wondering if anyone's got any suggestions.
Toe is correct at 1/8" in (and I've tried toeing further in as well as out), camber is good, and caster is about 6 degrees. Self centres nicely every time. No bump steer.
The only thing I can come up with is either I need more caster, or a steering stabilizer.
My pinion has lots of room to go up or down a few degrees, so adding more caster isn't an issue, but I figure 6 degrees should be sufficient. I've tried from 3 all the way to 6, and 6 is where it self centres well.
I didn't bother with a steering stabilizer, as my thoughts are that they're really only there to mask a problem. Perhaps I'm wrong? In a perfectly setup cross over, is a stabilizer necessary to keep the Jeep tracking straight?
By wander, I mean the steering feels a tad sloshy at high speed (but everything is perfectly tight) and I find it a bit of a chore to just drive down the road straight. Constant need for small corrections all the time, and it always wants to pull down the road crown, regardless if the crown is on the left or right. It all points to insufficient caster, but due to the excellent self centering, I keep looking for something else.
Idea's?
Idea's?
