Well I had some Adj Lower Control Arms and my coil was actually "S"ng bacwards so the post would rub, then on flex it would rest on the coil, and on compression it would snap off. So anyways, I bought some temporary Nth* arms for the uppers, to get me through winter. Well I toss them on at stock length. Now I found a chart that has A good start on what your measurements should be for arms. So my lowers were a tad long (I have 4"), and my length was for a rig with 4.5" and my uppers i adjusted and measured both be appropriate for the height I was at. Here is the issue, my drivers coil has hardly adjusted, it still sits pretty far back...not rubbing but almost. Also if I hit a bump, my drivers side sounds almost like I am bottoming something out, or hitting something solid. Any ideas??
Passenger Side
Front (see how I am a little slanted towards my drivers side)
Drivers Side (Messed Up Side)
Seating
And like I said, all the measurements on uppers are the same, and ditto on the lowers.
Passenger Side
Seating
