Ecomike
NAXJA# 2091
- MilkyWay Galaxy
I haven't tested the cranking voltage. I bought the CPS at Autozone. I wasn't aware about the CPS mounting customization, is it simple to do?
I haven't checked the grounds yet. I've been needing to do that anyhow for a while now (I drive a bucket of oil pretty much.) So I'm going to try that tomorrow and check the voltage for the CPS. You guys have been a great help. Keep the suggestions coming please!
The last CPS I bought at Autozone, Jan this year gave me no start problems for 2 months, but passed the meter voltage crank test, until one day when it was reading 0 volts for 2 cranks, then magically worked again, confirming poor electrical contact inside the plastic casting of the CPS. I bought the next one from Rock Auto (they had more than supplier in the 3 Standard products brand boxes I bought). The first one I tried worked fine. The CPS is a magnet and coil on the inside, and the coil wire is angle hair fine, while the lead to the connector is about 18 Ga. I took the bad one apart, and all I could figure is the mechanical crimp contact on the angel hair dia wire was bad. The mod is to drill out the CPS mounting holes using one drill size larger than the OEM hole, then while tightening the bolts, have something or someone force the CPS as close to the flex plate shaft (crank shaft) as possible. This will increase the signal strength, higher voltage output on the CPS.
