FUNKYTEE5
- Vancouver, Wa.
Ok here's my scenario! I just swapped head gaskets because I had hydrocarbons in the coolant and boil over issues. The head gasket is almost always the culprit right? Welp, I just got it all back together and running and it got up to about 200 and began blasting coolant out of the radiator. I could actually see the compression pulses with the coolant spewing out. The only other option that I can figure is that there is a small crack in the cylinders somewhere that opens up when warmed. Do y'all have any other thoughts besides a cracked block? I've never heard of a cracked 4.0 block!! AAggggh!
Thanks:explosion .
FUNKYTEE5
Thanks:explosion .
FUNKYTEE5
