- MilkyWay Galaxy
It is a common point for ground failure of the sensor grounds
Ok, I have replaced the CPS with a genuine part, I was able to find one locally. It seems to have helped with the cranking situation, no more long crank/no start issues. I have also replaced the TPS with a genuine part. My issue of accelerating is still somewhat there. When the trans auto shifts through gears while slowing down or speeding up there is a delay in acceleration for example but the RPMs will rise, trans will kick in, the I can feel it accelerate. Its almost like there is something holding the jeep back until it finally gears itself properly then the RPMs drop back down to normal.
So today while running some errands with the wife I got a CEL. I immediately did the key trick and was given a 12, 45...and then the 55 which of course is end of codes. On a 97 I have read this 45 can be either NSS or lockup solenoid. I am considering pulling the NSS to clean it but not certain this will resolve anything. Many say this code is too generic to really determine but just wanted to know what you all thought. Still having this strange shifting issue, RPMs rising until trans kicks into gear than they drop back down. Thanks.
It is possible, however I have adjusted it twice. Ill see if I can determine a test procedure for it.
Where do I test connector at TCC, which pins? The plunger can be pulled out and it ratchets, thus extending the range of the plunger. I was under the impression this was an adjustment.?
