Ok. Here are the findings after my extra set of hands came out and helped work the ignition switch.
ASD Relay
Pin 1, Key off: No Voltage
Pin 2, Key off: 12 Volts
Pin 4, Key off: No Voltage
Pin 5, Key off: No Voltage
Pin 1, Key on: 11.71 Volts
Pin 2, Key on: 12.14 Volts
Pin 4, Key on: No Voltage
Pin 5, Key on: 11.82 Volts
Fuel Pump Relay(With a Relay in the ASD slot)
Pin 2, Key off: 12.15 Volts
Pin 4, key off: No Voltage
Pin 5, key off: no Voltage
Pin 1 Key on: 11.72 Volts
Pin 2 Key on: 12.06 Volts
Pin 4 Key on: .003 Volts--had to set my voltmeter down to 2 volts to read
Pin 5 Key on: 11.75 Volts
These are my findings. This leads me to believe that the relays are getting voltage, if these numbers mean something else, let me know. More suggestions still. I am planning to bypass the TB sensors, and pull the Cam sensor(pickup coil) and see what I can do to try and attempt to get it to start. I am also cleaning up my spare NSS, but I am going to first "adjust" the one in the Jeep and see if that is the culprit, as I am finding looking at the diagrams that McQue sent me, they show that one of the wires goes or comes from the TCU, which if that also gets its power from the ignition switch, to me it would mean that maybe some of the starting circuit is my problem, which is being linked back to the NSS. But if I am getting the voltage at those circuits, then that would mean that the NSS is working correctly. Thoughts here now??? And thanks for all the input so far.
Jeff
