ihscoutlover
- Edwardsville
I am going to start backprobing/checking the fuel system, since I now have the spark figured out, and the check engine codes are showing clear. I have been working on charging the battery overnight, so that I can have a true 12 volts in the system to continue testing. I think next I am going to jumper the #2 and #4 pins on the relay and check the voltage back at the connector by the fuel filter and see what I get there. I think too, I am going to change the filter(since I am already back there), and see what comes about with that changed out, and see if I still have good pressure, as well as correct voltage/power by then. I will report back my findings. Also my other ECU came(thanks Matt), and we will go from there, as I will still be using my current one, in case there is a short/problem that I cannot locate, so I don't F up the replacement one.
Jeff
Jeff
