themud
- Scottsdale AZ
Ok so I dont know if this goes here or on Oem but Ill take a shot...Everyone at one time or another has had cooling problems with their xj except for some of us who have them everyday ( living in phx AZ) where it gets to a 110+ frequently, Its really trying on your cooling system mostly in stop and go traffic and thats pretty much all we have around here...After watching all the things people have tried done and failed with I have a thought process that tells me its not the raditator most of the time its the lack of air flow...Now no one has made the electric fan thing work yet (that I know of) I am thinking about yanking the clutch fan on mine and putting in a flex fan with no clutch just a spacer.
The problem I have is finding the flow #s for the stock mechanical fan tried the stealership their morons, tried part houses (same result) ...If I can find a flex fan that flows more air at idle than the stock clutch fan it should work right??? The problem is finding the cfms for the stock fan and aux fan and replacing both with fans that have higher cfm ratings and making sure I have a good seal for the shroud...Any flaws that I cant see, info, advice better ideas I am open to trying just about anything for the benefit of us all(well at least those who live in really hot climates)...
PS If youve tried it and it worked or didnt work please let me know also part #s helps for research..
TIA themud
TIA themud
