Hey folks,
I've owned my '00 XJ since November '18. When I purchased it, I brought it in for a check-up and round of service. Fast forward to yesterday, and I notice a coolant leak while at the gas station. Managed to tear into it today and it looks like the area around the transmission line is wet/seepy.
I also noticed that my coolant tank is low (about a 1/4 of the way to the "full" mark). I have not, however, noticed any drips on the ground when I've parked it overnight. Can't tell whether it only leaks under pressure and therefore I'm losing coolant as I drive or what.
Here's the wet/seepy spot:
I'm assume a replacement radiator is the best solution?
My research indicates that there isn't much reason to go for a super fancy radiator. Would this one suffice? Any other recommendations that won't break the bank?
Also...
What else should I plan to replace/update while I have pieces pulled from the engine bay?
I've watched a couple of youtube videos and I'm pretty confident I can manage the replacement myself.
What else do I need to perform the replacement?
I have the transmission line tool in my amazon cart.
How much coolant will a replacement require?
Any watch-outs while making the swap?
Also...
