Assuming the stock radiator is in good shape, and you see no indication that the engine is running hot, leave everything as-is and change the coolant every year.
If you are seeing engine temperatures rise past 230F during normal driving after flushing the cooling system, then consider putting in a stronger fan clutch. The USMW 22148 / Autozone Duralast 922625 fan clutch is a step stronger than stock but not as strong as the ZJ fan clutch. Good part about the USMW fan clutch is that its not nearly as thick as the ZJ fan clutch, so its easier to install. Also check to make sure that your efan is the late model style with more than 5 curved blades. And make sure that its working.
If you are still seeing issues after that, then time to review your cooling system more carefully. Verify that shroud is still fully intact. Figure out exactly what radiator is in there. Consider replacing the water pump.
