TYphoon
- Berks County PA
While it is not a cone filter at this point, there is a heat shield which would not change if the filter did. Tube and shield are made out of the same aluminum sheet. The tube will, probably at the same time that the filter is swapped, be covered with some sort of insulation.
How did you mount it?
