TYphoon
- Berks County PA
Looks like its a thin Building supply material used for insulating homes....
I see I see. Do you think I will notice any difference?
Let me know it turns out.
As far as the filter getting wet mine always seemed to stay pretty dry even playing in the mud could be because it gets so hot the water evaporates rite off of it.
Also you might want to try a pre filter or some panthose on the filter it will make cleaning your filter so much easier. keeps all the bugs and engine grime from getting in the ridges
i took the front of my 88 apart and trimed out some "excess" material and i have "cold air" comming in directly to my AMSoil filter. i made my tube and wraped it in insulation and made a heat sheild out of some super heavy plastic i can get at work. its not perfect but it does help a good bit. i need to fine tune it still.
What did you have made the shield or the tube if you made the tube what did you use as the elbow on the throttle body.
