jeepmike887
- Hinckley, IL
alright, starting to get to the bottom of this, might not be the bearings, the markings on the shafts are not too severe, but their is one about 4-5 inches from the end of the shaft, which is the wheel bearing, and another about 20" from the end, just inside of the leaf spring perch in the axle tube.
one of my friends is a lube tech at a dodge dealer, and he was asking some mechanics about this today, they said that limited slips take a special additive, as well as gear lube, did you put some of the ls additive in gene? if not, then its probable a combination of that and sitting for so long is making the limited slip tighten up. their are actually disks in the limited slip, that resemble clutch friction plates, I could watch them as I was spinning it and they appear to be stuck together, Im gonna put some additive in tonight, and try and break them loose.
