4x4JeePmaNthINg
- Colorado
i should add i planned on burning outside in with cooling in between. after tacking. burning into the pumkin last, the only plan i had was preheating and wrapping it to cool.
I'm gonna have to weigh my junk when it's done. But I think I'll be close to 5000ish. Or I could be completely wrong...
Need to get my under hood temps down to stop heat soaking the struts and steering. I'm not sure how much the exhaust leak contributes to the heat but I Need to fix that first to see ... The steering gets hot enough to puke fluid out so the pump isn't long for the world running those temps I have a 14 dual pass on it , but I think moving up to a 2.75 Cylinder is probably going to happen since it takes less pressure to move the tires with the bigger cylinder and should reduce temps . I just can't run a trail without cooking the fluid and puking it out .
You slipping George! You won't have underhood temps, if you don't have a hood, just saying...![]()
