time2getdirty
my cats breath smells
- Cheyenne, Wyoming
Re: The Colorado BS thread
You people need some Toyota in your life.
Truck for sale in 3, 2, 1...You people need some Toyota in your life.
Truck for sale in 3, 2, 1...![]()
Bum stop location question ... I was going to mount a bump off the frame just behind the shock on the form of a tube mounted 3 inches out from rail this put the tube in line with the lowe control arm just a few inches from the axle , but while flexed up I noticed the arm was only about 2 inches away from the bottom of the frame rail where the stock lower arms would mount , so I made a mount that I welded to the top of the control arm and intend to mount a poly bump to...The only negative I can see here is bendung the arm , but I think it should be good the bottom of the unurail there is plated in .500 - so no worries ...Any reason I should rethink this idea ?
A little give in a poly bump that far back and in is a lot of movement at the axle. Granted I don't have much experience setting up straps, but seems hard to fine tune that far back. :dunno:
Will you still be based in Mont-Rose?Well signed my life over today.
Back to the patch it is. Gotta train a guy to take my spot up here in crested butte, then I'll be transferring back to the fun. Was just burnt out up here already and the hours aren't what I wanted. But I was offered a senior spot so better pay and heavy hours. Goal is to live broke and pay off a bunch of stuff. See how it goes.
You need some paint in your life lol those rockers and rear bumper look a little rusty!
Dealer called today and said both codes thrown were misfire related and that I have three coils fried and needing replacement. Does it seem odd that three coils would go at once??
3 coils at once? Don't think so. Sounds more like either a wiring problem or cam timing related.
