Last time we were "stuck" in a drive through, I pointed to the pile of rocks they had in the median, told my wife her car would fit between the light pole and the bush. She didn't dare me to do it, but the thought did calm her down a bit.So got stuck in jimmy johns drive through for almost an hour....
Its not that good. at least at store by me. just limited options when ya can't cook.
You can be both at the same time. Good luck with the H.D. recovery.Just lost a hard drive in my computer with all of my pictures taken in the last 6 years, including my son's entire life. Backup was bad too. Can't decide if I'm pissed or depressed.
Put the hard drive in the freezer for 24 hours. Put it back in your computer and boot it up. This should give you some time to remove your pics before the drive heats up and fails again. Use this process over again until you recover all your data, or until this process stops working. Good luck. There are companies out there that recover data off failed drives, but they tend to be expensive.Just lost a hard drive in my computer with all of my pictures taken in the last 6 years, including my son's entire life. Backup was bad too. Can't decide if I'm pissed or depressed.
I have read this before, but that author said to put the H.D. in a zip lock bag while it was in the freezer???Put the hard drive in the freezer for 24 hours. Put it back in your computer and boot it up. This should give you some time to remove your pics before the drive heats up and fails again. Use this process over again until you recover all your data, or until this process stops working. Good luck. There are companies out there that recover data off failed drives, but they tend to be expensive.
