Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Mine has started popping right at the beginning and end of the stroke, and I think it must be the worn spot the pin the MC clutch rod rides on. Looking at your photo below makes me think this is the issue. Notice the flat, cut, worn spot on yours in the photo, at the top of the pin. I can see plenty of slop in mine with out removing it. Thinking I may need to pull the peddle assy and sleeve it or bush it somehow, or weld and grind it (Yes I bought my first wire welder :cheers
It also seems to need some washers on either side to limit the wander side to side. I seem to have left that area as is when I fixed mine over the Christmas holidays in 2011. It started barking at me last weekend. The weld on the crack has held up very well!!!
