Clocking a 231
Roxtar
Any special instructions?
ChuckD said:
Buy ans Atlas! :D
Any special instructions that don't require a $2000+ investment?
Yeah, haven't you read my posts concerning this? Remove the t-case. Use a compass with it's center set in the center of the output shaft and scribe a line around the center of the t-case mounting holes. Remove the auto tranny output housing. Have an aluminum rod turned to fit tight inside the original t-case mounting holes. JB weld or simply friction fit pieces of the rod into the holes to fill them. Sand the rod pieces flush with the housing. Mark new holes rotated as far as you want from the originals and drill new holes. Reinstall everything and your case will be clocked! Jeff
