prljeep
- Toledo, OH
90 MJ 4x4 Pioneer MT, 128k
I am 99% sure I have the dana 35 on the back (I have been looking for the multiple posts with the link to the axle pictures); however where do I check the fluid level and fill it up at? The fsm says the check/refill hole should be near the driveshaft on the upper right side if looking at it from the front??? I checked all over and could not find a plug???
AM I an idiot??? :huh:
Also, it looks like the gasket may be leaking at the rear end housing- do they make a replacement gasket or just use RTV? It appears to be a sloppy RTV job on mine at the moment.
Thanks- PRL
Thanks- PRL
