xalexjx
- Newcomb, NY
i have a buddy who has a tj with stock springs cut down one inch on 37's. And itll out wheel most any other rig on the rocks
i have dabbled between 6" of lift and 2.5" of lift on mah 37's
i prefer to be lower
Just figured out my jeep is exactly 1.5" higher than a skyjacker 3" coil with big bumper on the front. Lift only measured with a tape. centerline of axle to fender line. So if a skyjacker coil sits what they say it does. I am 4.5" with 37s
really? your jeep looks taller than that.... i'm still pondering fullsize axles one day....
you are also on fullsize axles tho which is pretty nasty btw i saw your rig up close at the GAJR
i'm at 4.5" with 35s, the only reason i could see going to 10" is if you really like your fenders.
i also dont think there is any sort of way to run a sway bar (safely) on 10" of lift. This must be the scariest thing to drive.
not a true fullwidth though.
my front 44 runs about 63.5" wms-wms
my 60 rear is around 62" wms-wms
and that means you saw my airplane wings![]()
