- Rainy side of Washington
15mm head, I want to say M10x1 or M10x1.5 thread. 10.9 or 12.9 hardware, I forget.
The problem with stock and C4x4 brackets is that they do not deal with angled pulls very well.
It is very easy to bend them unless, you are pulling straight ahead.
The IRO bracket spreads the pulling forces to both frame rails, the IRO square tube is not going to flex at all.
IOr if IRO just provided a piece to go up and catch the factory recovery point. A U shaped sleeve/bracket that went up to the factory tow hook mount would substantially reinforce the whole thing.
so you would think adding a U-shaped piece of metal to be sandwiched in-between the bolts of the swaybar, and the IRO mount would be best? Then you can capture the factory bolt locations on each side of the fram.
Completely agreed. However, one thing I'd really like to see is a version where the receiver exits through the middle of the stock bumper - cut a hole for the receiver to feed through and move the licence plate to one side to accomodate it.
Or receiver mount your license plate and no one ever knows the hole is there. That would also be pretty useful for removable winch plate.
Someone really needs to email this thread to IRO. Looks like we just did all the market research for V 2.0
Yup. Or plug it with one of these - they seem a little pricey at $40, though; it's the sort of thing that should be a $25 option at build time IMHO.
This is a really good idea. Who wants to run with that?
yes, which is why I never mentioned the other three bolts, just the single sleeved hole in the back.The only factory bracket bolt hole that is reinforced is the large on at the back end of the bracket. The rest of the factory bracket holes are just sheet metal.
The sway bar bolts are attached to a thick u shaped bracket that is spot welded to the inside of the frame rail. The IRO bracket is mounted in single shear, just like a Class-III receiver hitch.
I have emailed them a link to this thread.
as for d rings on the IRO mount maybe look over this thread that is on JF:
http://www.jeepforum.com/forum/f177...-building-xj-1116911/index5.html#post10814908
http://www.jeepforum.com/forum/f177/tj-guy-tries-his-hand-building-xj-1116911/index5.html
there are some pics over there of what a guy did to put d rings on that setup
the shackle brackets are cross drilled so they will fit in either orientation, horizontal or vertical.
they charged almost nothing, 5$ or less each im sure.
i picked the full size GM hooks because they would adapt to the XJ brackets the easiest by drilling one hold.
im sure the expedition hooks would be nice because, well they arent hooks, they are loops, stronger and more secure.
