M mn_xj NAXJA Forum User Aug 20, 2003 #1 How do you remove the new style center console? mine is a 97 TIA BEN
Ivan I Jeep, therefore, I am.. Location Greensboro, Ga Aug 20, 2003 #2 Pull e brake up as far as it will go, remove screws inside console box, and the sneaky hidden screw located under the tcase shifter bezel. The bezel just pops off with a pry from a small blade screwdriver. Pull console off... Ivan
