Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Have you run an IR thermal scan on the entire engine, manifolds, etc to look for peak temps and hot spots? You could have a heat soak issue on one or more fuel injectors, turning liquid gasoline to vapor and causing a lean condition.
How hot is the coolant actually getting????? Is the flow blocked in a spot and causing a hotter or leaner cylinder?
