- MilkyWay Galaxy
Under the hood tonight, checking all my electrical connections with my shiny new analog multimeter... what do I finally find?... The O2 sensor harness on the vehicle side is falling apart (One of the wires doesn't even stay in place, it just slides in and out randomly, you know the one that is supposed to send the alternating voltage). The TPS sensor harness is literally disintegrating inside the weatherpak. The MAP sensor connector is also having a rough time. Time to get some decent connectors and rewire those little buggers. Ten 3-pin Weatherpacks arriving at my door tomorrow for the refresh. Maybe that's why I couldn't get a consistent voltage out of the O2 sensor... How did I refresh all the grounds and not even notice that the connectors were in such bad shape?!?!? I feel like an absolute fool right now. I hope that this refresh gives some solid results. Fingers Crossed.
Note that the TPS/ECU 3 pin and MAP sensor weatherpack look the same, but they are not. Not sure where you bought them?
I had to use an exacto knife to trim some plastic on my TPS spare connector to fit the MAP sensors.
