i have a 96 xj with 3.5 of lift. i run 33-12.5-15. what size bumpstops do i need. any sugg. are appreciated. fenders are cut but nothing to extreme still have fac. flares
Stock XJ are 74mm (2.91"). XJ Up Country are 117mm (4.61"). The factory also offers two other heights, 90 mm (3.54") and 104mm (4.09"), which may be intended for use on MJs.
Once lifted, I'd go with the tallest ones you can get. Better to hit the bump stop than to bottom out your shocks or over-flex a spring.
