Building engine coffee table
An old Chevy six or (if you need more length a Pontiac/Buick/Olds straight 8) of the 50's makes a dandy table, because it sits pretty flat already. I used to use one of these as an anvil. One could easily have put a top on, and made it a table. They used to be abundant.
AFAIK, the same rules apply as to liscense plate collections, 2 rules; 1) you cant buy em for that, and 2) no dupes.
so, long story short, theres only 1 choice... our beloved amc 242!
I'll be building one out of a 4.0 after I finish the house. You'd be surprised how little one weighs once you strip it down, I'd say a bare shortblock is definitely under 250 because I can pick it up.
Waaaay under 250 bare. I'd say 125, maybe 150 max.
Although is not a coffee table, I think this picture belongs here too. I'd like to do a coffee table setup with an engine that I personally blow up, perferbly with a hole in the block or a rod thru it. Now that would make a good table with a great story. Guess I gotta exploded a motor someday....
Now that's cool, although the shifter taps are a bit odd lookin since there are two.
As for making stuff out of parts, ask Beezil about ring and pinions.
I'll have to check with the boss & his wife, but I'm thinking about a chevy I-6 coffee table for our shop waiting room.
Or a volvo B motor. Smallish, plentiful, strip it down & it should be easy enough to move. Cheap.
This thread has gone completely different than I though, and there are some really neat ideas. So, Ill just add some more pictures I have found over the years that I liked and want to copy.
Cut down vodka bottles. I tried this with some bottles and it sort of worked.
oooo Belvedre Vodka. It's made in the town I was born (Zyrardow, Poland). My great grandfather worked at that distillery.
Getting back to coffee tables, I just finished my latest IKEA hack. I turned this Hemnes coffee table into this trunk.
Use a Ford V8 - they're not worth a damn powering vehicles anyhow.
Same with the GM 305/307 blocks. They make great boat anchors.
For one of my old roomies, I made an ashtray with an axle shaft, brake drum and ring from R&P, works well to hold the cigs/whatever.
I think I've got a couple of old ring gears around (D30-size or so,) perhaps I should have a plate welded to the bottom and make it a shop ashtray?
Got a load of old parts around, maybe I can do something with them (got a set of inner gears from a D35 that make nice desktop paperweights...)
Back in my smoking days I was also driving old Peugeots. These had a worm drive rear axle (like a Model A truck), with a big bronze crown gear. A curly maple* insert in the base made a really elegant ashtray. I still have a couple of those gears around, though I sold my last Peugeot in 1974 and gave up smoking in 1988. I never gave up saving useless stuff though I guess.
* a stock of unfinished signs. Why? I don't remember, except that they planed down to beautiful stuff. Wish I still had some.
you could make tons of money off that second clock, patent the design and sell it to a company. I work for an import/export company doing the catalogs and our book is full of stuff like that.
i have plans for a few neat auto related welding projects. keep the pics coming so i can steal your ideas!!! mwahahaaa ha haaaaaaaaaa :firedevil
