Jeepedo129
- Henderson, NV
Rotate the inner c's and add WJ outers/ brakes
Thats a good idea, while the housing is bare. I know there are some Akebono knuckles and calipers sitting in PNP right now.....
Thanks man, So far Ive really liked the radius arms, This is my first long arm kit so I cant speak for others, but as it stand right now, I really like them, the ride is loads better, plus with the driveline dialed in it doesn't vibrate so driving on the freeway is awesome. the only draw back so far that I can see it with the high clearance arms, the come pretty close to my exhaust and the frame on the drivers side, so ill have to clear some more metal out. BUT that belly pan is PURE beef....
As far as the compressor....... it's still in R&D......
I got started with it and I'm ready to start putting pieces together but it just got pushed to the back burner. But it is still something I really want to do and depending on what happens here in the next month I ill get back on it. :thumbup:
here's what I built, HP30 from a 98 XJ, ballistic truss, home made C gussets, plated upper pass side control arm mount,, plated the trackbar bracket(it's thin metal and tends to wallow out.) 3/8 plate on the LCA mounts for skids(tied into the axle tubes) 4.56's and a list of stuff that I have to go on it. I have a total of $60 out of my pocket into this project.I do however have a question about building a D30.
I would like to buy a 30 from the JY and have it sitting in the shop to work on. I know i want a HP and a non disco, but other than that are there any special years to avoid or to look for?
Going to put a Ballistic fab truss possibly coil perches, jks track bar mount, C gussets and LCA skids.
then ARB 4:88, and alloy 30 spline kit.
anyway
more to come
good to know. I've got a spare compressor out of a 98 XJ with a bad bearing ($40 fix) that im hoping to use for OBA, I want to mount it underneath my power steering pump as well so I can keep my A/C and everything else, so i'd like to see how well the mounting works for you and how the heat from the exhaust manifold affects it. Its pretty far down on my list of things to do but if I beat you to it i'll be sure to fill you in on any lessons learned.
And I poser pic for good measure.
Any further and I would have rolled over haha,
but really I had tons more to go that's just the best I could do in the church parking lot. At full left lock at that much droop the TRE for the tie rod hits the sway bar..... So yeah
