philagony94xj
- Schererville, Indiana
Are your rockers in good shape?(read are there rust holes in them). If yes then weld these in as replacements, if no well then you could go either way(bolt-in or weld in).
So I guess I should update my thread. I've been drivin the jeep for a couple weeks, and my jeep feels brand new. No unibody echoes and dash board squeaks. The only issue I have is with the track bar mount. As I said above the 10ga steel between the frame and the mount have made the bolts not line up. My solution for now is I used a plasma cutter and oblonged the holes then put a washer on the bolts. Since I still have the stock track bar that isn't adjustable, my steering wheel is cockeyed. :doh:So the next on my list is an adjustable track bar.
Also, don't know if this is a track bar issue or the frame stiffener, but my drivers side coil is rubbing on the track bar mount when the suspension travels. Stay tuned.....
Looking good. Did you get your CB installed and tuned yet?
If I were you I would've put body seamsealer around the perimeter of the stiffener/s
Not a bad idea. I did this on my rear stiffeners when I installed them.
Like your build and REALLY like the write-up for the frame stiffeners, That will be on my ever growing list of things to do to my new XJ.
Keep the updates coming.
Nice progress, Brandon!
