Nope, haven't started yet. I feel like a woman as I keep changing my mind about things.
I do have to keep to the budget theme, since funds will be limited. I have so much into my current rig, easily 30k+ over the last 10 years, that I can't justify a big expense on another rig, even if I had it.
The basic plan as it looks now (if I don't change my mind again) is to build using a '93 XJ that I've found for about $800. It's all there mechanically, auto with a 231 and a basic lift, and the back has already been cut off. I found a GM D60 that I can get, and a HP44 center section, and would like to build a hybrid 60 using a 35 spline ARB in the D44 center section. For the rear I'll swap the Tera60 from my rig into the buggy, and I already have an XJ D44 that I'll put a 33 spline Super 44 kit into for my current rig. I still have a set of 35" MT/R's that I'll put back on the yellow Jeep, and put the 37's and beadlocks on the buggy. The front hybrid 60 will get 5 lug hubs and 1/2 ton brakes so the 15" aluminum rims will fit. Gears will be the 5.13's. I won't have dough for a t-case right away, so I'll see how the light weight and 5.13's work with the auto and stock t-case gearing.
There won't be much left of the XJ. Narrowed in front, no windshield, narrowed on the bottom, no floor behind the two seats. The only problem is that a plan is formulating but I don't have the money yet.........only a minor problem.
Hey Bryan and bigwoody, what size and type of tubing did you guys use?
