Broken "ears" on quick connect
coreys
Alpharetta, GA
While replacing one of my transmission lines this weekend, I noticed the quick connect on the other transmission line was leaking. I tried to remove the quick connect and the "ears" broke off of it (It looks to be the original). Now I cannot get the line out to replace the quick connect. Any suggestions?
I just replaced all of the QD's on my XJ this past week. Once the ears were gone, I had to Dremeled off the rest of the QD fittings and used hose clamps when I replaced the lines. ALL of the QD's on my transmission lines were leaking and I was told that you can only take them off a few times before they start to leak.
If you have any other lines with QD's, make sure you clean them out with engine/brake cleaner before you pinch the ears together.
