MrTwinkles
- NY
Hi folks,
1st time Jeep owner, recently acquired a 98 XJ Limited with 241k mi after looking for a few months, good value ones are very scarce these days so pulled the trigger when I found a clean-ish one.
I have only had it for literally 3 days thus far, runs and drives great and got to play with it in the recent snow we had.
Questions on the most glaring things i noticed:
1. Oil pressure: Been doing a lot of reading on this with varying conclusions on what is deemed normal/expected. 40psi cold idle/driving drops to 12 ish at idle (or closed throttle) when warm. Safe to assume the gauge is good at relaying oil pressure as it is ambient air temp at its age but the only noise from the engine is the sweet 6cyl sound.
2. Vacuum leak: Seems like there is a leak somewhere underneath the intake manifold, there is an audible high pitch blowing sound under acceleration and suction sound on decel. Also audible at idle when you stick your head in the engine bay. Should be an easy fix but would like to know what is all controlled by vacuum reference.
