O-Gauge Steamer
- Colorado Springs, Colorado
I believe that the kits they are referring to is the top mount ala Avenger style kits. It will use the stock manifold as a base. At least that was the plan when I last saw the prototype. They took the prototype to the last SEMA show in Las Vegas. Last I heard, Sprintex was working with Perfect Power to address the problems with the fuel/ignition control that the SMT-8L has. I had an issue with it that proved to be insolvable and resulted in my moving it out in favour of an AEM F/IC8 and new injectors. I went with the F/IC8 so as to gain speedometer calibration. The F/IC6 will work just fine. Just make sure you get the one for the Dodge Neon. Chrysler used a different from the rest of the world current value in the PCM to detect injector misfires. So, the Neon version of the F/IC6 has different load resistors in it to prevent CELs. The F/IC8 already has those resistors so it is a non-issue. Functionally, the PCM fires the F/IC and the F/IC fires the injectors. There is a delay but the AEM procesors are fast enough so as to make little to no difference. The AEM uses two processors to keep the signal latency to a minimum one processes and controls the injectors and the other spends it's time lying to the PCM about the Crank Position Sensor and the Camshaft Position Sensor signals. Both are digitally delayed to provide the spark retard you need under boost. I have had zero CEL events with the AEM. Only complaint is the O2 offset table does not want to play well with the Chyrco PCM and I need to in order to be able to run E85.
And trust me on this, you need the bigger compressor because we have tractor engines. You need the boost right now, not later. Going up Briargate (yah, I know) Blvd here in the Springs, I take the hill in OD at 40mph with about 2lbs of boost. If later is good then look to a Turbocharger. Boosterworks makes a beautiful manifold.
As far as I know, unlike Whipple, Sprintex will only sell complete kits. Whipple sells components for the do it yourselfer.
Once I am in a position to do the Whipple intallation, I will document it. Just don't hold your breath as I am stuck having to completely rebuild a Currie HP 9" rear. Changing out everything except the gear set and the Detroit. Not cheap (read in excess of $1.6k) when you have to pay for the labour...
Root Moose, there are two Stroker cranks as there are two basic Rover blocks. The 3.9/4.0 use the small mains and the larger displacement engines use the big mains. So... It will depend on what the Customer owns. Anyone remember the Buick all aluminium V-8? Rover bought the tooling when GM stopped building them. Lots of potential there. My friends and I are looking to build a blown 5.0 and swap it into a YJ. Should be fun...
