aparke4
- Atlanta, Ga
hi i am going to 3/4 or 1 tons and need to sell these guys - located in atlanta GA
front axle - dana 30 - 4.56 with true trac or lockeright cant remember - diff oil change about 15k ago, superlift diff gaurd (zinc colored ones), stock diff cover, alloy usa outers - right side installed with new 760 u joint, have left one in box with new u joint - got these in like new condition and have maybe 800 miles on them (on usa outers) - stock shafts besides alloy usa outers, pads and discs in good shape, brakes work fine, some normal wear and tear but no dents or anything - my xj has 95k so this axle has same miles on it - bearings are good too
right knuckle for lower caliper bolt stripped when removing for right side alloy install - common problem - was not very well helicoiled in- i can get knuckle if needed/ caliper bracket
make offer
dana 44 - out of wagoneer - 4.56 gears with synthetic oil and detroit full locker - stock 30 spline shafts runs great - same track width as cherokee - ran with RE leafs and 33's for a long time and 36's for about 2 months - street only with 36's- has superlift diff cover
great rear end
both have normal surface rust and are complete drum to drum for 44 and disc to disc for 30 - ready to bolt both in
make offer for 44, 30, or both
in Atlanta and both axles are currently under my jeep but can remove whenever
pm me for best response
both axles were never abused and have proven to be road worthy - both have seen a lot of DD and i have maintenanced them appropriatly
make offer
great rear end
