BlueRockRash's DD XJ Build
Re: New rig
Do you still have the drum parts? I could use them to fix my junk i hope
Re: New rig
If I didn't strip the retaining bolt it would have took me 4 hours total with the most time grinding the center of the backing plate out. And sealing back up the diff cover.. as hard as a brake job I would rate it
Cool, sounds pretty simple then. Just don't strip the hardware.
Re: New rig
Went to pick n Pull looking for this jeep and i found it!
It had just about everything i needed on one vehicle..
Here is the difference in older style XJs and newer style xj E fans upgrade!
Also got the front skid which i wasnt planning on grabbing but for 15 bucks why not.. Newer style side mirrors, a roof cross bar, and a sun visor with a mirror..
Had to search for a 3rd brake light and center console
While searching i found these guys
The haul
Got everything installed
Re: New rig
Picked this up today from Rob707 3 inch zone offroad coils and leafs. JKS trackbar mounted to a stock Trackbar bracket, and a sway bar with fresh bushings.. The lift is only a year old i dont think it had very many miles ran on the lift all the bushing look brand new.
i also hooked up a Sub and 2 new speakers for the sound bar..
And added a kill switch.. Some Cheap insurance.
Re: New rig
what did you get suspension wise there?
Re: New rig
Last drive stock to the parts store...
New coils
Quick little bend
I messed up.... my bumpstops are to big and when I dropped the rig off the jackstands it's ridding on the bumps. Gotta take the coils out and cut the bump stops.
It's taller then I expected
Got the longer studs from napa along with u bolts
And boom lift is on and done!
Before and after
Prairie city today for the Norcal jeep cherokee group meet and greet..
Stuffing those 32s
that white rig turned out looking awesome David!
Re: New rig
sweet coming together nicely. Also like the look of jk moab wheels on all xjs, good choice. Now get that rear done!
FIFY!
