BleepinJeep
- Kingston, TN
Any worr with the ORI mounted on the axle C? Maybe plate of like the kits that are out there for the d30?
No, its basically a C gusset with a hole on the top.
if you look at his mounts, they are basically giant C gussets.
OP, your fab skills are great.
your axle choice still sucks.
I give this thing a month on the trail before its on tons.
:cheers:
i would use a large ID tube or C channel to put a relief in the frame where it contacts the link. with all the tube work i dont see it being an issue.
Will there be a console? That might affect choices for placement. For instance I would consider mounting the CB (or better yet, Ham radio--get your license, my 11y.o. just did) in the console.
The console might also be a good place for the winch controls. I find that reaching forward to the dash is awkward. Height and worn out joints may be a factor there.
I love your build.
So here is where I'm at now and I need your advise. I have the dash all mocked up but how in the world do I figure the best placement of all the crap I need??
Here is what I think I'll need but I'm sure I'm missing some stuff:
•I'm using the stock gauge cluster
•Heater Control
•I'm using a circular marine radio
•Front LED lights switch
- Dimmer for front LED lights
•Rock Lights switch
•Front locker switch
•Winch on switch
- confirmation light
- In/ Out switch
•Battery Cut Off
•Fuel Pump cut off?
•Speakers?
•CB?
Am I missing anything??
Any advice on where to mount these things? Any advice on how to mount them so I can easily access them?
If you are doing a console I would locate the winch controls and the front locker switch there where they are easy to reach while paying attention to the trail ahead. I have found the space between the shifter and the arm rest to be easily accessed without needing any visual confirmation. That can matter when things get interesting.
I would put the headlight switch in a position as close to stock as possible. That way you can find it more easily in the dark. Alternatively, go sit in your rig in the dark with a Sharpie in your hand. Reach forward for where you want to reach for the headlights. Wherever the Sharpie marks your template that is where to put your headlight switch.
Those would be the functions that matter the most to me. Fit the others in around those in such a fashion that you don't accidentally end up with the wrong function when reaching for something else.
Make sure you can reach everything fully strapped in.•Front locker switch
•Winch on switch
- In/ Out switch
•Battery Cut Off
•Fuel Pump cut
•Heater Control
•Rock Lights switch
•Winch on switch
- In/ Out switch
•Battery Cut Off
•Fuel Pump cut off?
•Speakers?
•CB?
Do you still have AC?
