big daddy tie rod
how do you slightly use a tie rod?
did you put it in, and put your hand on the wheel and said, on second thought i wont turn the wheels? :D
you have it, you run it and you don't bend it :D Btw, I bought it used and never ran it.
ruggedjeep said:
Remi, i meant to ask you @ calico, what steering setup are you running?
I got the steering from Avanteone. Setup is like JCR but it includes extra poly piece (I believe JCR gives you only one but two is better :D ) and he can actually ship the same day you order ;) The setup is the inverted T with the chevy 1 ton tre's.
Hey Remi I would like the tie rod. Let me know if its still available.:bunny:
