muddeprived
- PA
I got a slight left-hand pull. I'm getting replacement joints for my RC long arms and they are sending me a replacement crossmember as well so i want to use this time to get the "perfect" wheelbase set since I have to disconnect the arms from the xmember. Usually I just measure from center of hub to center of hub but it's not entirely accurate since you can't really tell if the steering is perfectly straight and if it's not the measurements won't come out right.
What is the best method in measuring and setting the wheelbase on both sides? Should I use the axle tubes instead? I heard that aligning the front axle to the rear axle would correct pulling issues sometimes. How is that done?
Thanks
Chris
Thanks
Chris
