Since joining up as a vendor here a few months ago you guys have simply been awesome! I also had a great time hanging out with everyone at SoCal Fest in Big Bear and figured I'd say thanks in the best way possible. Go to StinkyFab.com and use the coupon code and you'll get $29 off a pair of our engine mounting plates. That's the biggest discount we've ever given on these and brings the price down to $200, WAY lower than any competitor, especially since we already have the lowest regular prices.
Don't wait until this happens to you! This unfortunate Jeep owner had one of the OEM engine mount bolts break and the other 2 ripped the mounting bosses right out of the block. Needless to say this made for a very bad day and sadly this is very common. Often not only does it damage the engine block, but when the motor falls the fan damages the radiator and hoses, wiring harness gets torn, etc. Our mounts prevent this from happening by using a number of additional mounting points to spread the load across more of the engine. Needless to say spending a little ahead of time can save a lot in the long run, especially when you get a deal this good!
