Lowrange2
- Abbeville, SC
Har har har. I got too much money invested in this trip to not show.
Change fluid in both diffs. Getting some occasional not-so-nice noises from the 8.8. Hope to not see too much bad when I take the cover off.
Shake down run with new steering set up.
Find a trailer (got a tow pig lined up). Worst case, rent a uhaul trailer.
Would like to install the frame stiffiners i've had for two years, but don't know if i'll have the opportunity to get to that or not.
Oh, and fix the radiator and water pump that decided to start leaking last weekend....
It would be nice if you were closer we could get all that done in a weekend
It would be nice if I could weld worth a crap too...
Practice makes perfect.....
Come down and practice any time. I have spare rooms if you wanted to make a weekend of it my friend!
I can make stuff stick together... It's never pretty.
Indeed it does.
May take you up on that sometime soon.
Lilkewise. Haven't done much of any welding since my machine shop/motorsports days in College. I picked it up pretty quick then but have forgot most of the little tricks to it now.
Have my winch mounting brackets/plate ready just need to get my neighbor to weld it up so I can install my winch....still waiting to get with my neighbor to weld this all up
Ordered DOM and heims for my tie rod since LRG bent my tierod enough to worry me last year so I need to measure cut and have the inserts welded in once it all arrives...then hope it will fit OTK. Parts are here just need to measure and cut tubing, drill knuckles and have same neighbor weld inserts into tube. CUT AND MOCKED UP..JUST NEEDS KNUCKLE DRILLING AND INSERTS WELDED
Still need to shave the 14B so Nick won't yell at me...should be happening this weekend. DONE!!!!
Need to get ramps made for my trailer.
Still hoping somehow I will have the money to put some swampers on the MJ...but I think I'll have to wait until next year. (NOT GONNA HAPPEN)...anyone have $1100 I can borrow? There's the perfect set of tires in our own FS forum!! AAHHH!!
Now to add more...traded the 95 cummins ram toward an 03 cummins ram so now I have to reinstall my CB and invertor in the new(er) truck and I ordered EGT and trans temp gauges yesterday so there's another half to 1 day of work. Good news is now I will save some money on the fuel for the trip since this truck does better...but then of course now I have a monthly payment again...boo...but it's worth it. CB AND INVERTOR INSTALLED...GAUGES SHOULD BE HERE TODAY
Maybe change the oil.
Made a new list:
Replace shock
Build front Bumper
Install winch
Check brakes
Paint front end
Swap transmission This was the big thing...
Add some speakers
Remove Reese hitch
Fix power steering whine
Find 97+ grille
New battery
Check cooling system
Wire e-fan to toggle switch
Check gear oil
T-case fluid
Make half doors (Time permitting)
Have tire vulcanized
Add exhaust hanger
Limit straps
Build rear bumper
Build Traction bar
Replace leafs
Replace leaf perches
Fix yoke and drive shafts
Reinforce sliders and brace cage better
Rewire rock lights
