before the crawl my junk needs.....
Holy cow really? Last I checked they were close to $200, but then again I won't need brakes or anything, I just put brand new Wagner stuff on mine a couple weeks ago
Yeah. There's a different price for a "complete" axle. If memory serves I beat the brakes and hubs off it in the yard to make it "incomplete" and cheaper. Didn't bother me as they were items I would be obviously replacing anyways.
Sweet, and I could completely remove the knuckles if I wanted
things still left to do for mine are t-case skid need to find away to make one for it FAB work. rear brakes need to be done. get swr set on antenna. change oil. put winch on. light bar installed and wiring for light.
Help Tim and Nick with what ever they need if they need it.....
My heep!
Compression check... Done 90/120 on number 6.
New battery=Done
Fix Starting issue=Done
Fix drivers seat.
Find spare front DS or buy one....
Fix brakes, they work but could work better.
Dream list:
knuckles for the 60
35 spline outers for the 60
coil overs front? Jury still out on this one.
chop rear and 4 link with 4 suspension seats... jury still out here too...
Well at least its some progress......
Mine needs a front locker (lsd is not for me). Needs seats and cage (can't do cage without seats so I can build around them), looking for some wj leather seats.
Re: Re: before the crawl my junk needs.....
Your locker situation will soon be fixed.
Made a new list:
Reinforce sliders
Replace shock
Build front Bumper
Install winch
Check brakes
Paint front end
Swap transmission
Rewire rock lights
Add some speakers
Limit straps
Build rear bumper
Remove Reese hitch
Fix power steering whine
Find 97+ grille
New battery
Check cooling system
Wire e-fan to toggle switch
Have tire vulcanized
Check gear oil
Add exhaust hanger
Make half doors.
Got a few things knocked out. Added a few.
new u-joint in front drive shaft - DONE
new driveshaft straps - DONE
new front pinion yoke - DONE
repair spring holder on drivers side DONE
a couple new tie rod ends SKIPPING THIS ONE
repair snapped off bolt in the differential housing -DONE
maybe a new ball joint. Firestone says it's bad. I'm doubtful. -SKIPPING THIS ONE
Replace fluid in rear axle DONE
Repair broken track bar DONE
Get one new 31" MT DONE
Pick up spare long shaft DONE, tie rod ends, drive shaft
Reinforce front bumper or replace with a non-crappy model
Mount new spare on factory rims
Route cowl air induction system DONE
New negative battery cable
Run auxiliary input to the radio
Axle seals Done!
Replace rear shocks
Limit straps
Bump stops
Dana 44 lube locker
Fix cb
Install bucket seats- fab up bracketry
Brown dog motor mounts
Replace Trac-bar bushing and bolt
Replace u-joint in spare driveshaft
Touch up rust spots
Flush fluids
Install Johnny joint for Dana 30
Dana 30 Ubolt style yoke
"Find truck and trailer to haul my junk
Not likely bucket list:
Make and install a traction bar
Install bead locks Done!
ORS bumper
Synthetic rope and non roller fairlead
Truss front axle - tomorrow!
Haha I don't know how to mark it done all cool like
well, it appears after winterfest the list grew.
fix brake brackets
install belly pan
install super duper short shafted 242/cv driveshaft
quarterpanel armor
fix the angry sparrows in the front driveshaft
paint and general freshening up
Better get to working then!
got a pair priced at the local pick a part, just waiting on tax returns!!
Hope to see y'all again too High2by and Flex. I have been on the lam.... not really, just dealt with some issues over the last year. Things are getting back on track now, so hoping to be Jeepin again soon.
fix brake brackets fixxored
install belly pan
quarterpanel armor
fix the angry sparrows in the front driveshaft fixxored
not a bad weekend.
-Fix shock mount that broke yesterday
-Redo the other shock mount in a better way
-Fix axle side track bar mount - DONE
-Seals and ball joints up front
-Replace bent factory control arms with straight ones - LOWERS DONE
-Replace rear driveshaft - DONE
-Weld and blow up my D35 at URE and swap in my 8.25
-Sliders
-Tires - DONE. Need 33" spare now
-Make rear doors removable (if time permits)
Add:
-Front pinion bearings
-Front locker
-Way to carry 33" spare (roof rack most likely)
Made a new list:
Reinforce sliders and cage.
Replace shock - Done
Build front Bumper - Done
Install winch - Done
Replace kinked rear brake line
Paint front end - Done
Swap transmission
Rewire rock lights
Add some speakers - Done (It's nice to hear music in this thing for the first time in years.)
Limit straps
Build rear bumper
Remove Reese hitch
Fix power steering whine - Done
Find 97+ grille - Done
New battery - Done
Check cooling system - Done
Wire e-fan to toggle switch - Done
Check gear oil
Add exhaust hanger -Done
Make half doors.
Little update. Making more progress than normal. Going for a test run this weekend to see what else needs to be done...
