northernxj
- Marquette
I sound deadened and filled my rear hatch with poly fill to eliminate rattles from my sub. The rear hatch is significantly heavier. The factory shocks/hydraulics that hold the lift gate open do not have what it takes to hold the hatch open. It will close on you when you open it, or will stay open enough for me to fit under, but I am like 5' 6'', so I was seeing if anyone has come up with a solution for worn out, or inadequate lift gate shocks. Any suggestions, other than removing the polyfill, are welcome. Thanks a lot,
Stephen
Stephen
