- Southern Maryland
Fixed some of the worst rust, still have a lot to do.
This is what I found in the wheel wells, basically where the water is flung off the tires had gathered up and rotted through the sheet metal. Looking at other Cherokees and now I see that this is a really common problem area.
Cut out the section as much as we could without going into the frame rail or around the curve into the rocker. Still some rust inside above the frame rail but I am just trying to fix this so I can get through Winter. Next year sometime I will replace the pans and rockers.
Same on the drivers side too
I thought there were two layers of metal but its actually just one layer of metal and then a skim coat of seam sealer.
Ended up just cutting a patch that was taller than the hole and tacking it in place. I got a piece of brass from a welder in the local jeep club to use as backer for stitching the sides but couldn't make it work. The numerous tacks are holding the metal on solid, so we went with that and packing everything with seam sealer.
3M seam sealer over the outside edges of the patch
and a skim coat on the inside
After that dries, I will put some underbody spray on the outside and some Herculiner on the inside.
Not the best work but it should get me through the winter and spring, which is all I was trying to do at this point
