- Westminster, SoCal
OK, so I have the weld on bead locks welded up, all is painted and I'm going to be getting the tires mounted on them tomorrow. I have the bolts all ready (32 per wheel ) as well as the nylock nuts (I opted for those instead of nutzerts, long story). Anyways, being that I"m often overly cautious I'm wondering if I should also use a drop of blue locktite on each bolts? Just to be on the safe side?
Also bolting them on: bolt them on in like the wheels (across, across, acros) or in a circular pattern? I was thinking that I will probably want to bolt them on in a cross pattern first to get the ring down and the rubber somewhat compressed and then in a circular pattern to the point where all is good and tight at 15ft/lbs.
